william hamilton
Hi all,
I am currently scopingn out solar panels for my robotic dairy farm which is currently using an average of 110 kWh single phase electricity from the grid daily, with a usage pattern which is relatively even, filled with equipment turning on and off 24/7 (compressors, coolers, water heaters etc).
I am currently planning to have 2 x 5kw inverters which (when should cover most of the equipment, - the grid will have to step when lots of equipment is runnign at once, but 10kw will cover 90% of the time.
As almost 50% of my load is at night, i am hoping to include a potentially 20 kWh+ battery pack to try and supply for the night as well, in order to charge these, i am hoping to massively oversize the solar panels (40-50KW), however i am concerned that the inverters won't be able to take this.
Is there a way for the inverters to only draw max 10kw, but the batteries be charged direclty from the solar panels? as opposed to being charged through the inverters?
