wpns
Solar Joules are catch and release
I'm looking to add some solar panels to the roof of my 'garage', which has sections mostly facing east and west:
(Yes, pressure washing and painting is first!)
So I'm looking to see what my options are. I can do it manually (while the roof sections are trapezoidal, the 'square' pieces are 354x158 inches, approximately, and there's the vent pipe to deal with if I start extending past the square section).
Is there a standard inter-panel spacing that I should use that'll work with most racking systems? My existing array has about an inch between panels in the 'clamping' (wide) side, and a fraction of a inch between panels on the top/bottom (short) side, so I'm assuming one inch between panels in one dimension and not much in the other.
Is there a standard panel size? My Good Friend Google says there is, but then when I drill down to the details of any particular panel I'm looking at, they are all a little different, and I'd hate to specify an array size and be a couple of inches short when I go to clamp the panels onto the rails.
Does portrait versus landscape make any difference?
Is there a tool that'll take the size of my roof and help me design the array?
Thanks!
Thanks!
