Once again, still working on my shed project.
This is a small, off-grid, EG-4 3K system. I plan to have roof and wall mounted panels, which I've already purchased from Santan Solar. While checking into racking, one of the vendors mentioned that panels needed to be a minimum of three feet from the roofs edge.
However, I've seen lots of youtube's showing similar projects, and spacing about the same as mine. And, this is an unoccupied structure that isn't connected to the house. Is the three foot thing real, and if so, does it apply to this kind of project?
Quick EG4 3K question
I'm still working on my shed project and came across a little confusion. https://diysolarforum.com/threads/wiring-question-for-120vac-system.74764/#post-949618 EG4 provides a 125 amp breaker with the 3K inverter, and shows instructions on how to wire it. But, Will's video doesn't use it...
diysolarforum.com
