HI all! New to the forum, so apologies if this is an old question - a quick search found nothing...
I'm currently spec'ing out a battery storage + solar install for my house. I'll be building a DIY 48V LifePo4 battery (tying to decide between 14 and 28kWh) and initially using it to take advantage of cheap electricity prices overnight (I'm based in Scotland). Eventually I'll add solar panels to top the batteries up (during spring/summer/autumn). I'm looking at a parallel inverter setup for something like 12-15kW continuous AC output maximum.
My question is about the battery connection/charging. Ideally I want to AC charge my battery at ~150amps so I can fill it in 4 hours (it will have a 200 amp bms). If I have 2 parallel inverters - each capable of AC charging the battery at 100amps - will they share the charging burden? I'm not sure if they would co-ordinate in this way. And if not, could I split the battery in two and have each connected to its own inverter to achieve the same effect? What would be the pros/cons/potential dangers of a split battery configuration?
Thanks in advance!
Thanks in advance!
