frankz66
Hello everyone and thank you for accepting me. I am not very experienced in PV, I wanted to ask for some opinions from experienced users regarding my configuration:
2 180 watt 12v photovoltaic panels for one, so 360 watt totaili.
1 Epever 3210 AN
1 Electronicx 110 amp battery 12v c100 AGM
1 reverse green cell 12v/24v 500 watt max 1000 watt pure sine wave.
I find great doubts about the configuration of the software and asked as written before if I need to retouch some parameters as shown in the photo:
The battery manufacturer only provided me with some information about charging the battery, namely the boost to 14.40, the float at 13.62 (20 c°).
I just changed the equalization that should not be done on AGMs as they do not have the ability to "boil" ...
I set the compensation to -3 (but I don't know if it's correct) and the following values:
Float at 13.60 (to date unfortunately I have a temperature of 32 degrees)
Boost time at 30 mn
Equalization 0
110 the correct value of the battery
But do I know the other parameters, such as the discharge volts and how much?
I also use a constant load of 36 watts for 24 hours. In the morning I find myself with 12% of the battery!
1 Epever 3210 AN
Boost time at 30 mn
Equalization 0
