Hi folks,
Thanks to all previous posters and commenters, I have found a couple of MPPT options, but I am not 95% confident they will work.
If anybody could help me understand the parameters that are actually critical, I would be very grateful.
There are a lot of constraints I am trying to live within on this project, so please bear with me.
Project is a solar roof on a golf cart. The golf cart is older, and is 36V, which has proven to be less common.
I am trying to stay in a reasonable budget. The first impact of this is I would prefer to use a panel I can buy locally as surplus, instead of ordering panels that would be better suited for the job.
And all of that puts some heavy demands on the SCC, which I am also trying to keep affordable.
I am willing to take a reasonable risk that the charge controller will be a failure, but I would be grateful for your expertise.
So....
Golf cart solar roof means a horizontal panel, so I lose power right off the start.
A panel that is locally available is the Longi LR5-54HPB405, which is the right size to cover the cart.
It has STC numbers of:
Voc 37.15
Vmp 31.2
Imp 13
Since I have 36V batteries, I have been looking for a Buck/Boost MPPT that can handle the amperage.
OPTION 1
This one is sold by Lensun. One real nice thing is it has a cooling fan.
So, the nominal voltage range will cover a lot of panel performance...but what about the amps?
Again, this panel will be flat, at 49.6 degrees north, so I am assuming it is going to miss out on a lot of potential photons. Will that be enough to put the panel output in the safe range for this controller?
The next two controllers are 20A
OPTION 2
This one is the most expensive, but seems like it meets the needs. People in this forum say good things about ECGSOLAX.
There is very little info, like whether it has a fan.
The item listed on eBay says it has an amp range of 11-20. Is that actually too high? Will I have enough amps to make it work?
BUT, when I messaged the seller on AliExpress, they recommened this one:
OPTION 3
Tracer 2206
This one does not seem to have boost. They messaged that it will work for 36V batteries (see picture).
But the picture does not seem to jibe with their webpage.
If anybody could help me understand the best option, I would appreciate it. Thank you
So....
Voc 37.15
Vmp 31.2
Imp 13
OPTION 1
Lensun Buck Boost Solar Panel Charge Controller 24V 36V 48V 60V 72V Battery
www.lensunsolar.com
Product Parameters
Nominal Voltage: DC 12V-50V
Maximum Current: 12A
Rated Power: 18V/300W. 36V/450W
Battery Voltage: 24V/34V/48V/60V/72V
working Temperature: -20℃ ~ 60℃
OPTION 2
OPTION 3
Tracer 2206
Tracer AN Series (10~40A) MPPT Charge Controller
EPEVER Tracer-AN adopts MPPT(Maximum Power Point Tracking)technology. This mppt solar charge controller capacity range from 10A to 40A.
www.epever.com
