Depending on your peak winds and your panel area, your pole may be insufficient. The pressure loads due to high speed winds on a flat plate on a pole with a moment arm can be pretty impressive. A 30 mph wind perpendicular to that array will put be an 800# load. 50mph would be about 2200#.
If it's 10' in the air, that's 8000 and 22000 ft-lbs of torque, respectively trying to snap the post.
