Chri5co63
This is a view of the screen on our PowMr 3000 w Solar Inverter Charger unit, during a sunny day with PV Input to charge the batteries. At the same time, the generator is running. However, the generator does not seem to be inputting into the system. The only time that the generator inputs is when there is no PV input (such as at night). We have also tried running the generator on cloudy days, when very little PV is inputting, to allow generator to add to the charging of the batteries, but still no connection path from generator is indicated on the screen (one thing we have NOT tried is running a heavy load in this scenario such as an air conditioner to see if input energy from the generator would be called for).
Is this normal? Is there a setting in the parameters for the PowMr, that I do not have correct? Does there need to be a significant load for the generator input connection path to be viewed? Does it have anything to do with Parameter setting 07, 28, or 36 (Max. Charging current set at 40a, Max A/C charging current set at 40a, or PV charging current set at 40a, respectively). These parameters were set as per suggestion from the Chins battery Representative. Incidentally, we have the Battery Charging mode (parameter 06) set at SNU so that both solar energy and utility (generator) will charge the batteries at the same time. The PowMr manual further states for this setting that, "MPPT Solar energy will be priority charging and when it is insufficient, Utility will become priority. When the photovoltaic energy is sufficient again, Utility will stop charging." on a cloudy day, wouldn't the PV energy be insufficient enough to allow the Utility (generator) to charge the batteries and/or supply energy to load?
I mention parameters 07, 28 and 36 only because they seem a bit confusing to me as the settings are all equal, while in the PowMr manual it states that Parameter 07 is the Max charging current = utility charging current + solar charging current. If Parameter 28 and 36 are set at 40a, wouldn't the setting for 07 be 80a? Even the Default numbers in the manual do not make sense to me as they are [07] 60a, [28] 40a, [36] 60a.
