Off-Grid-Florida
- Oct 10, 2021
- 3
I have purchased the 6.5kW 48v MPP *all in one* system and need help with the battery configuration (and panel options too).
The company I purchased from claims that the minimum amp hour requirement for the battery bank is 200-300 ah.
Will 4 Battleborn 12v batteries connected in series suffice?
Do you have recommendations for a larger 48v battery that can handle a partial load? (We will not be using the full 6.5kW anytime soon and likely will not exceed 3kW for a couple years until our home is finished)
Regarding panels, I have so many options that it makes my head spin. I am considering buying used panels (80-90% of rated wattage) but am openminded and will also consider new panels if anyone has suggestions. We do not need a full 6.5kW array yet but if we buy used panels, it is very affordable and we may do it.
One final question... will a full 6.5kW array cause damage to the system with insufficient battery capacity? Will the 4 Battleborns in series (or 300ah+ 48v battery) be enough?
Thank you in advance!!!
