candersen
Syncro T3 from Chile
- Jun 7, 2020
- 11
Hello everyone ! Greetings from South America ???
I built a 150Ah battery 1 year ago using a BMS and installed it in my camper van with a Renogy DC to DC 50amp charger yesterday (solar mppt + alternator charger). When I started my van for the first time I noticed in the app that one of the cells triggers the "cell over voltage" protection from the BMS as seen in this video:
I did not balance the cells when I assembled the battery because to my knowledge the BMS could handle that ? is this the proper way the battery is supposed to be charged and is it safe and healthy? Should I disassembly and top balance the cells? ? I’m really worried because I should start my long awaited trip from a 2 year van build in 2 more days
Separate question: when I started the van with the battery connected for the first time you can see in the photos attached that in the app it says is at 8% charge, but magically 2 minutes later it’s at 100% and the cell over voltage is kicking in.
Solutions are much appreciated! Thanks for the feedback and help ??
