What happens if the 3 panels in series produce over 115v that the MPPT solar charge controller can handle? Does the MPPT just shut down, burn out..? Or as Hunter937 discovered, voltage goes in but nothing comes out? Shutdown? Does it restart on these units automatically? the solar controller is on even if the inverter is turned off, correct? and why we need a breaker/shutoff switch on the wires going in?
The "Y" connector is interesting.... sort of like purposely shading the beginning of the one panels cells? not sure if that would be top or bottom, wherever the cell's series starts... right? to limit the current just enough to keep it within the MPPT range up to 115v... either way is bothersome, but a factor of using these All-in-Ones it seems.
