Pretty good. I made a 2nd similar pole mount. I like it! A simple setup. The posts, U-bolts, and wood back-plate concept can be found at your local big box store. The Aluminum C-channels and a thick aluminum plate, I had to order and wait a few days before I could pick them up at the local Grainger store. You could probably improvise the Aluminum C-channels with 2x4's or Slotted super-strut or something along those lines, but I was trying to keep things light. Though you do need something fairly sturdy to support the panels.
I tried 3 panels on one pole mount. It works, but it was not balanced. I think it would be OK if I off-centered it to compensate and had I permanently set the pole in the ground (concrete). It looked similar to the leaning tower of Pisa. Although, it's probably too much panel for the pole mount in really bad weather conditions (ie. Hurricanes). 2 large panels seems a good fit for this type of mount.
Currently, I have two 390W panels on each of the two pole mounts. Easy to pivot up/ down and left/ right throughout the day when I'm home. I just used some wooden shims from an old wooden fence slat to wedge between the U-bolts and the poles to allow movement and to hold the set positions. It's been working well, even with inclement weather and temperature changes.
I still haven't permanently set them. I just dug a 2 foot hole for the ground pole. I've been apprehensive to make them permanent as I may have to slightly re-locate them to accommodate for changes in seasons. I have a small back yard with shading challenges that changes throughout the year. Also, I'm usually experimenting, testing, setting up mock-ups then bringing some of the stuff up to an off-grid recreational camp. I can set the pole mounts up and take 'em down on my own without too much trouble.
Cleaning the panels is pretty easy as well. I just use a soft car wash brush on an adjustable pole to brush off dust, pollen, leaves, etc... then I change to a car squeegee with foam scrubber attachment and a spray bottle of water to get the rest (ie bird poop, pasted pollen, etc...). Cleans-up well in 10 minutes or so.
I'd setup more of them if I had the room.
Currently, I just have loose 8AWG wires running from each pole (panels are wired in parallel for 24V Nominal) to an indoor sub-panel box used as a combiner box then to the charge controller. I'm looking for a reasonable alternative to the expensive combiner boxes. It'd be nice to find one that costs less than the solar panels.
