Pretty simple, as the title suggests. I've read quite a bit over the last few weeks and have seen endless debate over whether a disconnect should be between the battery negative and load, or battery positive and load. I'm not an electrician, but it seems that there is a fair amount of misunderstanding about how power flows, and rather than assume, I'm just going to lump myself into the group of ignorant and misinformed.
I was about to throw my disconnect on the negative side, but the battery disconnect I have (Blue Sea m-Series 6006) shows it being on the positive side. Is there a standard for solar/DC applications? If so, any pointers or references would be hugely appreciated. This is going in an RV, in case that makes a difference.
