Going to go with 200 watts of solar on the roof and a good controller/batteries for my setup thanks to the info you gentleman provided. I feel confident this set up will do the job. Still have room for more solar on the roof if need be. Thanks for your help!!
Sounds like a plan. Whether it’s enough will depend a lot on where you live and if you get sun all day or have a lot of shade. Also depends on whether or not you intend to be able to tilt the panels or just go flat. You’ll get significantly more solar production if you tilt them. Most RVrs just go flat and use more panels because the cost and weight of tilt is too much.
If you can swing it, rigid panels are the way to go. If you must go with flexible ones, the only ones that are worth buying and affordable at the 100W Sunpower. In the States, they’re sold by sunpoweredyachts.com and you get a decent discount using code “rvwithtito”. About $160 each free shipping. We’ve had three of these and are impressive how much beefier they are over our other ones that are only slightly cheaper. But rigid is best for longevity. Don’t expect flexible ones to last more than 10-15 years, but it also depends upon where you intend to be (hot climates with poor installation will kill them quicker). Let me know if you intend to go the flex route and I’ll help you decide if it’s really a good option or not. This forum hates flex panels for good reasons, but ours have lasted over 5 years now but I think it’s in part where we travel and how they’re installed.
For us, our 7.4cf fridge, which I think is just under twice as big as the fridge you mentioned, uses 50-60W when the weather is cool (outside temp 50-60F). It uses 70-90W when weather is warmer (outside temp 80-95F). When we only had 200W of solar panels, it was enough power the fridge in the peak of summer. But in the early and late summer, it struggled. Now we have 400W of solar and that changed the game. We also have another 200W solar that unfolds to setup on the ground.
So if you think you might want to add more solar in the future, be sure to buy a charge controller that can accept additional solar input. Or be prepared to buy an additional charge controller when you do upgrade and have a space in your camper somewhere to install an another little box with wires coming and going. If I were to suggest a charge controller that would work for you now and be able to expand in the future, it’s the
Victron Smartsolar 100/30. We paid $192 in September for it and Victron just dropped the price on these down to $128, free shipping. It’s a solid piece that you won’t ever regret buying. Much of the solar kits out there are pure junk. I wouldn’t recommend most of the kits out there.
