mhinz
Hi all
I have a very strange behavior. I use a PowMr 3200VA 24V connected to daly BMS and 24V battery. When I use the PowMr offgrid (without 220V input) all works just fine. But as soon as I charge the battery via utility source my internet router (Swisscom via cooper cable) looses internet. Only turning the charging off and hard reset of router solves the issue.
First I thought it is because of EMI, so I put the inverter 10m away from the router and covered it with a metal shelf/frame. Still interference. Then I thought it might be because of the WiFi Dongle, but disconnecting did not solve it.
Now I guess it could be that while charging it messes up too much the power supply frequency? But router is connected to a DC adapter, should should not have any impact.
Does anyone has similar experience and maybe even a solution?
