Electrobob
I have a couple Growatt 3000 24v Solar inverters and when I need to change out batteries or connect batteries to them after being disconnected I want to avoid the spark during the final connection. I have tried attaching a Brightstar 50 watt 6 ohm resistor between the last cable end and battery lug before making the final connection, but this isn’t working. What happens is the Growatt will turn on for a moment, then long beep and then turn off. I hold it touching together for a while but when I attach the cable I still get the spark. The Growatt has a 60 watt idle consumption so I suspect I am just a little shy on the resistor watts. Do you agree? What wattage resistor would you recommend using, or is anything above 60 watts suitable? Could there be another reason this is occurring? Sorry for the newbie question. Thanks for your help! ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
