I'm going to be installing a Grundfos 11SQF-2 with a CU200 controller.
Input power will be 120V from the inverter of an off-grid system.
I want to pump to a conventional domestic pressure tank, with the pump switched on/off by a pressure switch
The CU200 has input terminals to connect a tank level switch, and I'm trying to figure out if I can use these contacts and just connect to a normal 40/60 pressure switch.
Amybody else using an SQF with a pressure switch?
