Hey everyone, I have 8 304 AH EVE cells on the way and they should be here within the next few days. (Ordered through Alibaba the end of November). I have a LV2424 Hybrid Inverter Charger and an 8s JK BMS which I believe has active balancing capabilities of somewhere around 5 amps.
Can you kind folk help me understand everything else that I need in order to get this battery bank set up properly? I am going for a 24v bank. The battery will be a house battery for a school bus conversion. I believe the bus bars for the cells comes with the cells. I just don't know what the easiest way to get the batteries all balanced correctly is. Will the BMS balancer do a good enough job if left for a little while? Do I need to get a separate 24v charger? ( I don't have one). What about compression of the 8 cells?
Any and all guidance is greatly appreciated.
Thanks!
-Ross
Thanks!
-Ross
