AI4KK
Hi, I've been using a Remco 12 volt 2.2 GPH 60psi severe duty pressure washer pump to pump water from my IBC tote to a 25 gallon pressure tank. For some reason the pumps only seems to last a few weeks and then stop pumping, they still spin but no water comes out and on my first two I was able to blow water or air backwards through the pump... the third one is still hooked up and I haven't tried that yet.
Any idea what's going on? I've talked to Remco and they say this should not be a problem for that pump... I'm thinking maybe the pump is not made to withstand that kind of constant 24/7 pressure and maybe they just never considered that kind of use, usually people hook it up to the water cube and the pressure washer, do their job, and then turn everything off and depressurize the system...I leave mine pressurized 24/7.
Thoughts?
Thoughts?
