Hello all!
I may need your help.
I have three 12V 100Ah LiFePo4 Smart BMS with self-heating installed in parallel in my motorhome, connected via Modbus and monitored via Home Assistant - so far so good.
Now I noticed a strange behavior:
When I draw >180A (so 60A per battery) the battery bank shuts down, even though they are rated for 100A per battery.
After removing the modbus communication between the batteries, I was able to pull >250A before my (too small) breaker cut the power.
So it looks like the batteries are communicating with each other and acting as one battery, but the BMS is not raising the max discharge current to 300A.
Has anyone noticed similar behavior and/or have a tip on how to solve this problem? (other than not connecting them)
Thanks in advance,
Oliver
Thanks in advance,
Oliver
