Anyone know the difference between the KG and newer KH models?
1. Pop-up window reminder function: When setting over-voltage, over-current, over-power and other protection reminder functions, when the detection value exceeds the set protection range, a pop-up window will pop up for 5 seconds to remind. The old KH reminds the protection function There is only a very small English character displayed, and there is no pop-up window reminder. Many customers say they don’t understand what it means. The new KH not only has a pop-up window, but also has Chinese large-character reminders, which are easy to understand.
2. Buzzer alarm function: When setting protection reminder functions such as overvoltage, overcurrent, and overpower, when the detected value exceeds the set protection range, the buzzer will sound an alarm. When the old KG reaches the protection critical condition Sometimes only the relay will be disconnected, and there is no sound alarm reminder. It is not easy for users to find the problem, and the relay wiring is relatively complicated. Not everyone can easily connect the relay. After the new KH has a sound reminder, even if the relay is not connected , the user can deal with the problem in time after hearing the alarm reminder;
3. Real-time date and time function: it can display the date and Beijing time, and you can better control the time during driving; the KG time of the old model is running time, not real-time date and time in the true sense. When the historical data is exported, Without date and time reference, it seems very inconvenient. When designing the new KH, our technology has optimized this point, which can display real-time time. After the mobile phone is connected to the KH, the KH will automatically read the time on the mobile phone. ,Very convenient;
4. Bluetooth password setting function: The Bluetooth password setting function has been upgraded, and you can set the Bluetooth password by yourself, which is more secure; in the past, KG did not have this function, and RV riders would play tricks on each other after downloading our APP and then setting the parameters of the neighbor’s KG , with the password function, you don’t have to worry about similar situations anymore;
5. Shunt shell: The new KH has an increased shunt shell than KG, which solves the problem of installation and fixing. In addition, with the protection of the insulating shell, the equipment is not easy to be damaged;
6. Default brightness by time period: The new KH users can set the brightness percentage of the daytime screen and the zero-degree percentage of the night screen according to their preferences, and there are three ways to turn off the screen. Turn off the screen, the second is to set it to 0, the screen is always on, the third way is only mode, only when the current becomes 0 means that it is no longer working, and the time lasts for 60 seconds, the screen will be turned off. In addition You can also manually press and hold the key to switch the screen with the same hand;
