KS_Kampers
I give up... I've searched through the forum and have not found a clarifying post.
Here's my dilemma... I may need to do an emergency charge on my boondocked 280Ah SOC battery from my 2019 F250 with a 150A stock alternator. Perhaps to simply get a slide in and get on the road.
I have a Victron Smart Solar 100/30 combined with a small solar panel setup (two 100W panels in series) that we use to refresh our battery while boondocking. Our power needs are typically very small. No inverter being used at all. However, it is possible that after several overcast days, we might be in need of bringing the battery up using our alternator to get packed up and go.
What are thoughts about using a 10AWG jumper as a jump charger from my vehicle battery terminals while running alternator directly to power my solar charge controller?
Can I safely use that solar charge controller as a buffer to protect my vehicle?
Any words of wisdom on how to perform the disconnect if doing this?
