Hey everyone,
I'm seeking some guidance on correctly sizing a PV array.
Here's my challenge though, I'm trying to figure out the size of the Solar Array required to power a 3kwh system using a 3000 watt inverter and a single 48V/100 Ah rack battery. The maximum PV input for the inverter is 5000 w.
Here's how I went about calculating the PV array size:
1. Using an inverter efficiency of 94%, that requires my input power to the inverter to be 3191 w.
2. If I assume a battery efficiency of 90%, that means the input power to the battery should be 3546 w.
3. Let's ignore minor system losses for simplicity. If I assume 10 sun-hours (its very hot & sunny where I am in the Caribbean), then I need a daily PV power production of around 355 watts.
4. If I select a 315 w panel (VOC 39.9 V), then it would seem I require just two (2) panels to satisfy the battery.
5. The inverter, however, is rated for a maximum PV input of 5000 w and requires a PV array input voltage of 120 VDC to 450 VDC.
6. Considering these parameters, I can satisfy the PV array input voltage with just 3 - 4 panels in series but the input power will be only 1260 w.
Sooooo, I guess my question is, when sizing the PV array, should it be based on the battery charging power requirement OR on the inverter power requirement.
If I base it on the inverter power requirement I would need around 12 panels in series. This would give me a total PV array input voltage of 480 V and a total input power of 3780 w.
Your thoughts??????
Your thoughts??????
