sun_of_a...
Hi, thanks for help. I'm looking at getting a EG4 18KPV Hybrid Inverter and making one solar array of 55 panels: each string w/ 11 panels in series, w/ the 5 strings paralleled. Array: 20kw / 41 amps / 487 volts. (Panels are REC 365AAs). One pair properly-sized positive and negative DC cables 350 feet long from array to the EG418KPV (DC Input Voltage Range 100–600 VDC and Maximum Solar Input 21kW.)
From the EG418KPV manual: "The inverter has three MPPT PV charging circuits. MPPT #1 will use up to 25 amps which means two strings can be paralleled for any modules having less than a 12.5 A (Imp) rating. MPPT #2 and MPPT #3 will use up to 15 Amps each so they are usually limited to one string."
This question is supplying 2 or all 3 of the EG418KPV's 3 mppt input circuits with the single pair of properly-sized 350 foot positive and negative wires bringing DC at 20kw and 41 amps and 487 volts (of course with some voltage drop). Can I simply split/splice the 350ft cable pair into 2 or 3 pairs to supply 2 or 3 of the unit's 3 mppt inputs? I would think not, but the following sentence from the EG418KPV manual makes me wonder:
"The array can have a higher Imp than the 25A/15A specified, but the MPPTs will not make full use of the extra current. Having an array that can produce more current than the MPPTs will bring in is useful for increasing morning, winter or cloudy day solar production."
Also note, "The inverter will limit the total MPPT current to 25 A for MPPT #1 and to 15 Amps for MPPT #2 and 15Amps for MPPT #3."
Let's just assume properly-sized wire for now please. Would this work, and (leaving amp drop due to distance aside) would it utilize the full 41 amps of the big solar array naturally?
Thank you so much!
Stu
edit, added :
PV Input Data
Number of MPPTs 3
Inputs per MPPT 2/1/1Max. Usable Input Current 25/15/15AMax.
Short Circuit Input Current 31/19/19A
Unit Startup Voltage 100 VDC
Load Output Minimum Voltage >140 VDCMPP
Operating Voltage Range 120–500 VDC
Full Power MPPT Voltage Range 230–500 VDC
Nominal MPPT Voltage 360 VDC
Maximum Utilized Solar Power 18kW
Recommended Maximum Solar Input 21kW
Thank you so much!
Stu
edit, added :
PV Input Data
Number of MPPTs 3
