400bird
Solar Wizard
If you look at the attached spec sheet, the panels have 6 mounting holes down each long side. The center most pair say "Tracker"
These panels are nearly 90" long, so using the center pair of holes leaves you with 3' of unsupported panel balanced in a pair of holes 16" apart.
Thoughts? Am I interpreting this wrong?
Detail B just shows the hole/slot dimensions.
