eXodus
- Jul 27, 2020
- 1,482
yes with inverter, pretty much same setup as OPNo problem, as long as it is momentary.
You could also implement a relay as above, if you needed to run without shore power or generator.
Edit: that's assuming that you have an inverter.
- the generator always provides a ground neutral bond - even when not running. Adding a relay would add another ground neutral bond in the system?
