As of now I am just using a single deepcycle battery, Intil I finish building everything, and I am not running anything crazy off of it, last season I used it for my trailer and I only use it for running my lights, which I swapped out and everything is led like 7 w bulbs and maybe charging iPads, and I hardly even run it, I have solar lights that pretty much do the job to provide lighting. I m planning on upgrading my batteries slowly as I can afford, i would like to diy it like wills examples of the 3.2cells or maybe the 100ah battlebornes but I need to save up, it would be ideal if someday I had enough of a system to run my trailer furnace, that would be nice, I am in Canada and it would allow me to prolong my stay without resorting to a mr buddy heater which I don’t feel safe using after all the info I’ve seen on YouTube, I don’t know how much of a system I would need for that though so maybe one day I’ll get to that point.
So as you say about the inside wiring being small in the inverter I’m using 4/0 wire from 4 posts to 2 then to battery,
To maintain a clean look would I be safe to connect on the inverter posts positive to positive neg to neg, then a single wire from each, eliminating four wires coming from inverter to only two.
Thanks guys
