whereitsat42
Hi there, had two quick questions I was hoping someone would be able to help me out with (I checked the docs linked in the forum and didn't see a clear answer to these):
1)Do the wires I connect my batteries to a bus bar with need to support the combined input from the panels and output to the load, or just whichever is the higher of the two? In other words, if my panels produce max 40 amps and my load is a max of 20 amps, do I wire for 40 or 60?
2)Does the wiring for each battery need to support whatever the answer to #1 is, or can I get away with dividing that number by the number of batteries? So if the answer to #1 is 60 and I have 6 batteries, can I wire each battery to handle 10 amps, or does the wiring connecting each battery to the bus bar need to support the full 60 amps?
Thanks to anyone who can help, you guys have been really helpful in helping me get oriented and I appreciate you all taking the time to share your expertise!
Stu
Stu
