Thank you for responding all. Timselectric, I too would like to overpanel as it seems with the current LV2424 I'm running for my koi pond set up with 10-200 watt I have yet to hit the 2000 watts they are supposed to put out so figure the new set up will no doubt fall short on power production as well. Trying to find panels with an Isc at 9, or at least below 10 is challenging. I have learned from this a person should plan the entire set up before buying a single item. Live and learn. Sounds like 250w panels meet the 18a limit, watts are not very high though. Wonder why MPPT Solar didn't consider the new panels higher power ratings when engineering these?
SolarHandyman, wish I'd known this before jumping on the LV6548. The LV and the EG4 look so similar I'd bet they are built in the same factory by the same people. MPPT Solar needs to step up their game. I had read somewhere on this forum a person could put more amps to the LV without frying it but don't recall who posted that or what they stated was safe. Some of the panels I've plugged into the Midnite solar sizing tool comes out with 19.5 & 20.5 amps. These were the silfab and Mission solar panels I can buy locally for very reasonable price. So, if there's like 19.5 amps and 3800 watts in a string available, what will the LV6548 actually utilize? Also, I know with time the watt production drops, is this also the case with the amps?
Thanks for all your responses and help.
Z
