The voltage rating of 125vDC for these little breakers is a bit low for a couple of my PV arrays. Looking around at a few different options I notice that some DC breakers use a serial connection method for a claimed higher DC voltage. They do this by turning a 2 pole breaker into a 1 pass with a jumper from terminal 1 to terminal 3. The input for the positive DC than is in from terminal 2 and out to terminal 4. So the question is would running the Westinghouse in this way double the DC voltage capability to 250vDC?
An example of Midnites solar 300vDC pictured below:
![1719755056698.png 1719755056698.png](https://diysolarforum.com/data/attachments/225/225642-ba87df58bf59637381cfbdcb34e26ff2.jpg)
