Good evening, I have a quick question. Im using an lv6548 with 2 sok rack batteries. Using communication and noticed the Float voltage setting is set to 57.6 after setting it to Pylon on setting 5. Also the low voltage is set to 44 v instead of 48v. Is that normal? Should I set it to user and set the settings manually?
