Mike.Indiana
- Aug 11, 2021
- 23
I have 8 SOK batteries made into two 48v 206A banks. I'm feeding two MPP lv6548 inverter/chargers to power my home. Essentially the system for now is operating as a whole house UPS (ground mount solar panels will be installed in the spring). Everything appears to be working so far..
My question is concerning the correct battery settings for the MPP.
I calculated bulk charge voltage to 58.4v (14.6v * 4).
I set max bat discharge current to 100A and charge current to 30A per SOK specs.
I am unsure about the following MPP settings:
Cut off voltage ?
Float charging voltage ?
Battery Equalization (EQ) - enable?
Assuming battery EQ enabled..
Realtime activate battery EQ ?
EQ time out?
Battery EQ time?
EQ period ?
EQ voltage
Back to grid voltage?
Back to discharge voltage?
Can anyone shed some light on the proper settings?
Thank you.
Michael Fox
Cut off voltage ?
EQ time out?
Battery EQ time?
EQ period ?
EQ voltage
Thank you.
Michael Fox
