jibberishballr
- Aug 4, 2022
- 35
Hi there,
I've had ongoing issues with my Lv6548 since I bought it and have had to "patch" the correct serial numbers to make the unit work. MPP suggested this could mean a part was swapped, but I haven't swapped anything since I bought it new. Every time I apply a fix, it works for a few months and then I'm back to tech support to fix it. I turned the LED display off intentionally (to avoid it being a bright light at night) but last night something happened and both SolarAssistant and Watchpower don't "see" the inverters anymore. The units both appear to be running and I can monitor battery voltage from my BMS. I just can't manage my system now.
Is there a way to turn the LED Display back on while it's off without being able to use SolarAssistant or Watchpower? Looking for a workaround to at least be able to look at what the inverter is reading (e.g. any faults, settings changed, etc.).
Thanks in advance!
Thanks in advance!
