fmeili1
I understand the difference and especially the different behavior about surge load and large inductive load capabilities.I just caught up on this thread.... Gotta toss something in here.
I run Samlex EVO LF Inverter/Charger. LF because it handles my well pump, compressor, MIG Welder & more and never any flickering or noise on the 120VAC line. If Charging from Genset, Pure Sine Inverter type, again No issues, no flicker or noise. If Charging from my Big Construction genny (not inverter) the EVO passes the sinewave through and there is some flicker & noise. You can actually hear motors (fridge, freezer etc) "grumble" and LED's (cheapo's not the Phillips or EcoSmarts) do flicker terribly. The cheapo "Walmart"ones actually BUZZ, tossed them fast.
Finished a new offgrid solar install for a neighbour on the 23rd. I installed a different LF Inverter for him, a Value Grade 3024 (identical to an AIMS 3000W/24V LF model) and he has a "filthy" 15 year old Basic Genset... Oi, it floats from 100V to 125V and frequency floats from 52Hz to 67hz... okay, it is quite fugly, the Pure Sine inverter still passes that mess through and I have Never Ever seen such horrible flicker, even with low watt incandescent.
Inverters/AIO's when taking "non-grid" power are subject to whatever the AC Source is putting out, they will NOT fix the sine wave or clean it up. HF Inversion is Hyper Sensitive and in a sense delicate - it is really NOT intended for motors & heavy devices unless way over built and that would push their costs above LF Inverters. LF Inverters with the large capacitors & Torodial Coils are designed to handle light to extreme & even "hard" loads like motors, this is also why they can handle 3X surge vs HF's 2X surge.
HF systems are attractive for ONE Reason - COST ! They are Cheaper & Lighter than LF.
Sadly, this is where "Dollar Wise & Penny Foolish" comes into play!. Spend the $ and get LF and suffer No Issues with all gear in your home or save a few pesos and suffer issues, especially if "motor heavy" with Big AC, Fridges, Freezers & Pumps, let alone Commercial/Industrial applications. FYI, if you look at Industrial Solar Systems, they are ALL Low Frequency.
Good article that sums it up.
Inversion Methods Explained: High Frequency vs Low Frequency | Magnum Dimensions
Understand the difference between high frequency and low frequency inverters with this quick article.www.magnum-dimensions.com
In principle, both limitations could be somewhat reduced by oversizing the HF inverters and maybe by implementing a soft start circuit in front of some large inductive loads (I've done both oversizing and soft start for the central heat pump). The very short voltage drop when a large load kicks in, is a principle problem of the HF inverters (not enough iron to store energy for short times), even if they are oversized - but most people could live with just ONE short light flickering if these loads start.
But I don't really understand why the LED pulsing will happen permanently while a "dirty" load is running - not just at the moment when it turned on. Do you think this could also be explained because of the different amount of "iron" in the transformers between HF and LF inverters? Maybe it's because of the higher switching frequency of an HF inverter which may result in a more sensitive feedback loop of the PWM controller - just an idea. If the flickering would NOT be because of the less "iron" in the transformer compared to an LF inverter, I still have hope to find a type of filter for the HF situation to stop this oscillating problem.
