Im setting up an offgrid system for a remote cabin in CO. Basically to run lights, music, charge phones, small fan, etc. No really heavy loads.
In your videos you say to connect positive lead from charge controller directly to the inverter, not to the battery first. This leaves the possibility of the main breaker tripping and isolating the controller from the battery. This allows current to flow from the panels to the controller with no battery connected? Is there a reason for this or is this an oversight? It seems like the positive from controller should connect to battery side of main breaker with the inverter and DC fuse block on the load side, correct?
Secondly, You say not to use the DC load connections from the charge controller? You "just dont like them". Why? It seems that you lose the advantages of the controller. The controller should protect overdischarge from the DC fuse block. I see that the loads drawn from the inverter may be too much for the controller but the DC block should be relatively low loads. Running the load directly from the battery may ruin some expensive batteries.
Thanks, I do really enjoy your videos. I also noted that several others have the same questions but havent been able to find the answers. Cheers
