Desertdwllr
- Jul 7, 2022
- 56
I have 2 EG4 6500's running in split phase and 2 EG4 lifpower4 48volt 100ah batteries. I recently hooked up 6 540watt Znshine bi-facial solar panels, 3 in series to 2P1 PV1 and 3 in series to 2P2 PV1. I had the batteries hooked up to 2P1 via the included cables and 2P1 set to EG4 and 2P2 set to User. I didn't have error 61 issues however the inverters randomly drop power for 3 - 4 seconds then comes back on. I have noticed the alarm light will flash on the inverter for a second then turn off without any indication of a fault code. I updated the firmware to the EG4 6500's last night but 2P2 dropped power 2 times after the update. I am able to see the drops using solar assistant raspberry pi under the graphs for output voltage. I was hoping it was firmware issue and it still might be... I have not updated the firmware in the battery's. Power dropping seems to happen when the battery's are fully charged in Utility mode. Based on some other threads I have read, I set both my inverters to User mode, unplugged the communication between the inverter and battery's, set bulk charge to 57V and float to 56.5V. I suspect there might be an issue with the EG4 battery setting causing some kind of hiccup. Just a wild guess at the moment. Ignore the large dips in the second screen shot, I was hooking up different loads to the inverters and had things turned off. I'm wondering if anyone has experienced similar issues and what steps they have done to remedy it. I've also made a setting cheat sheet to make checking the settings a little easier and thought I would post a picture. I have it in excel and am happy to share with anyone or take tips on anything I should change.
![power dips a.jpg power dips a.jpg](https://diysolarforum.com/data/attachments/119/119019-fb6b298e11d5f2e9ce32a7874b491707.jpg)
![power dips b.jpg power dips b.jpg](https://diysolarforum.com/data/attachments/119/119020-7805e05a572070dda50c3d6bd59fd5c1.jpg)
![cheat sheet snap shot.jpg cheat sheet snap shot.jpg](https://diysolarforum.com/data/attachments/119/119021-350915c412319ddbb2a2ecb7467e61d6.jpg)
![cheat sheat snap shot 2 of 2.jpg cheat sheat snap shot 2 of 2.jpg](https://diysolarforum.com/data/attachments/119/119022-2030279dc3bd5c09a1f0023f8a4af3be.jpg)
