Actual power delivered, whether from engine turning shaft of a generator or PV delivering watts DC, would be active power plus losses. So I think closer to 60 kW.
Of course, rated power of PV panels under standard test conditions is greater what they deliver under nominal field conditions where they run hot in the sun. Clouds and dust/pollution obscure light. Some seasons and times of day, less light falls on the panels.
Is this a PV only system, no energy storage, no generator? PV array could be oversized so it provides what pump needs for several hours per day. Better, the VFD driving it varies motor speed according to available power. We can buy small residential solar pumping systems from Grundfos which do that, PV direct. Probably they exist for your size system also. "solar VFD" sounds like just that.
I don't think VFD driving 3-phase motor normally runs at a reduced power factor like 0.8, rather I would think it adjusts PWM width to close to 1.0 PF. I could be wrong. Some VFD are able to absorb power from load as well, providing braking like when an elevator is going down with load. My little one has a shorting link that can be replaced with resistive load, but I think some large ones could deliver power back to an AC grid. It could be, though that VFD does work with reactive power, and current flows back through transistors to capacitor part of each phase.
Does your system exist yet? Or do you have pictures of a neighbor's system?
Maybe I could measure waveforms of mine. But here are pictures from the web,, one idealized and the rest measured.
Photo about a Display Waveform Taken from an Oscilloscope. Image of troubleshoot, wave, scope - 1474804
www.dreamstime.com
Scope image in last one does seem to have a reactive component, not PF 1.0; current is shifted relative to voltage.
