Inq720
Odysseus, expert on the Siren's call
I'm renovating a small sailboat and will be installing a full solar system from what I'm learning on this forum. For this post I wanted to show-and-tell what I came up with for a small refrigerator/freezer. I probably should have asked for advice first, but made the jump without a net. I started out looking at Dometic, Waeco or Engel in the 50 quart range based on advice from this forum. However, the sticker shock drove me to Amazon and many hours of comparing. I finally picked an Aspenora 54-Quart Portable Fridge Freezer. Some of my criteria:
Anyway, I just received it last week and started testing it with the included AC laptop type power supply. Once I finish my LiFePO4 / Overkill battery, I re-run the tests with 12 VDC. Since the ship has sailed, I'm not likely to get something else, but I would be interested in feedback about the efficiencies I'm finding with this unit and/or other tests that might be enlightening.
Some Observations - I see the Dometic / Engel are more industrial and built like tanks and that the Engel even requires freight charges. This is certainly a lightweight item made mostly of plastic, aluminum walls a came by FedEx for free on Amazon Prime. I'll be building it into cabinetry, so I'm not too worried about it taking abuse from movement. It has more bells and whistles leaning toward home fridges.
PRO:
Ambient Room Temperature: 68°F
Using smart plug watt-meter. I'm sure not super accurate, but I've run the tests for at least 24 hours to reduce error.
Test 1 - Maximum Rate Freeze - This is to simulate turning on the freezer and dropping a 2.2 pound of fish fillets.
- Of course cheaper - Amazon had it 15% off for $340. https://www.amazon.com/gp/product/B082YWHMCY After the fact, I think it is possible to get it off the company site for cheaper... not sure. https://www.aspenoras.com/
- I wanted it relatively square - Many of the brands had "Ergonomic" shapes. I plan to build it in and will be adding 2+ inches of rigid insulation around to help the efficiency. The ergonomic ones make that a serious PITA!
- Having the handle removable - See 2 - Also it allows me to mount the freezer to boat structure.
- Having two compartments so freezer and fridge could be used simultaneously. This one does, but it is not regulated independently. Its simply the fridge area is over the compressor and must get slightly heated.
- Has controls and displays on top - Didn't want to have the insulation interrupted and will only have access to the top once installed.
PRO:
- Has a nice interior light in the door that shines down.
- Display temperature, mode is always showing.
- Soft close - I'm betting they needed that to protect the lid electronics from people who slam it down.
- Latch - Not sure if pro or con. Keeps closed, but won't fully close from a dropped lid.
- Noise - Quieter than my desktop computer and I don't think I'll be able to hear once built-in, but don't think I'd want it next to me while sleeping if not enclosed. Have nothing to compare it to, to know if its better or worse than say a Dometic / Engel.
- Vents are on three sides - 2 appear to be intake, 1 exhaust. Very slight heating of air. Not worth noting.
- Has two speed compressor - Max, Eco.
- The fridge section is 1/4" too short to hold my long-neck beer bottles! DAMN!!!
- Is lightly build. Will not take abuse like a blow-molded cooler or steel cooler.
- UI Menu is a little awkward and button presses don't always recognize. Once set up, I doubt I'd ever change it unless I want to change the main compartment between freezer and fridge temperatures.
- Start at room temperature
- Thermostat set to -4°F (delta -72°F)
- Mode set to MAX
- Pyrex 8"x8" pan with 1.06 quarts (1 liter) of water at room temperature.
- It took 1 hour, 57 minutes for the thermostat to reach -4°F and pause for its first cycle.
- Took 89.0 Watt-hours
- Took another 7 hours to freeze the ice solid.
- Took another 196.0 Watt-hours
- For three tests set thermostat temperature to simulate freezer, fridge and fridge in the islands.
- -4 °F (delta -72 F°)
- 20 °F (delta -48 F°)
- 37 °F (delta -31 F°)
- Mode set to ECO
- Empty contents.
- Door is not opened during test - Although not realistic for usage, I couldn't think of a quantifying opening schedule to be more real world.
- Start test once interior reaches a steady state.
- Run the test for 24 hours.
- In ECO mode the compressor, when running, draws 32 to 38 watts.
- -4 °F => 20.0 watts average over 24 hours, (481 Whr)
- 20 °F => 14.8 watts
- 37 °F => 9.0 watts
