I have two Growatt LVM-ES SPF 3000TL 's and EV4 LiFePower batteries. Growatt Wifi Module on each one, and I control them via Shine / server-us.growatt.com. I don't have Solar Assistant set up on a Pi. I often go long periods without physical access to the inverter. One just started.
This rainy week the batteries depleted too far and the units switched to grid bypass. But now they're stuck in grid bypass and won't take any PV energy. Searching the forums says rebooting these units is a thing. The only way I've known so far to reboot them is to cut off all three power sources manually (battery, PV, and grid.) But I often don't have physical access to them.
1 - Can I send a reboot command remotely? How? Best is to go through the Shine cloud server UI, maybe by writing a value to a specific register. If that won't work, I'd take sending a command via API or even VPN-ing in and sending a UDP command to the WiFi Dongles if necessary. Whatever works.
2 - When I'm there, is there an easy way to reboot it locally at the interface without cutting 3 power sources? How?
3 - Is there a way to poll the WiFi module to get immediate data, so I don't have to wait for the cloud server to update? The Shine cloud server has an "Advanced Read" button but I don't know any of the register values that might work there.
Thanks for your help!
