pollenface
I found this method for removing limescale from glass shower screens, maybe it will work with panels, I made the mistake of cleaning some of mine with tap water a few times
- Boil a cup of white vinegar and transfer it to a bowl or spray bottle before allowing it to cool. This mixture will act as your shower glass limescale remover.
- Use durable rubber gloves to carry the solution to your shower.
- Dip some paper towels into the hot vinegar and adhere them to the glass door. The acid in the vinegar should soak into the limescale and loosen deposits.
- Wait 30 minutes to an hour to allow the vinegar to break down the limescale. Periodically spray your paper towels with the vinegar solution to ensure that the glass stays saturated.
- Apply an ample amount of baking soda to a damp cloth or sponge and gently wipe down the shower door. Make sure not to scrub too forcefully to avoid scratching the glass.
- Use distilled water to rinse the baking soda and vinegar from the shower door. If you can see any remaining limescale, continue to rub the baking soda onto the door until the last deposits have vanished.
