Nesto514Rides
- Sep 19, 2022
- 13
Good morning, I have a question about the Renogy 500 amp battery monitor that I use. I just install my system or at least I start just started using my system this past Thursday, which was two days ago from this posting. My question is on the monitor. What is the highest reading that the time remaining will read? The reason why I am asking this is because I have a 200 amp hour lithium battery, the battery percentage, and the depiction of the battery with how many amp hours remain seem to be correct. The battery voltage, the amp draw, and the watt usage all seem to be correct as well, however, the time remaining has not moved from 99 hours and 59 minutes unless I am using a lot of power. My theory is that that number is the highest the battery monitor will register. I am speculating at this point that once my battery percentage drops below 50%, the time remaining will start to go down. The reason why I think this, is because I’m currently drawing about one amp, and with a time remaining of 99 hours and 59 minutes, that put it roughly at 100 amp hours. If this is incorrect, please let me know, and I would really like to know what the correct answer is so it doesn’t bug me anymore in a case and anybody else asks. Thank you and I hope this question is received well.
