OK, so it seems the battery is low and should be charging. Next step is to grab a multi-meter and poke the terminals the panels are tied to and see how much voltage your panels are sending. If it's below about 18v there's just not enough voltage to start the charging process. You'll have to figure out what your panels are doing and how they're configured. Hopefully you know at least how many of what size panels you have. If I were to guess (and this is just a guess without more info on your setup) you've got 1 or 2 basic 100w panels in parallel and there's just not enough direct sunlight to start the charging.
Let us know what the meter says and how many of what size panels you have going on. We'll get this figured out eventually.
