Been reading this forum for a while and excited to finally get started with a project of my own!
I may have the opportunity to pickup some used 10-year old 180w panels by Astronergy. I only have a blurry JPEG to go off, but it looks like model CHSM6612M, 34.39v, and 8.73a.
Use Case:
- Building a new 16x12 shed and would like some powered gable fans and LED lighting.
- Possible motion activated LED flood lights.
- Likely some Raspberry Pi's for tinkering
- Thinking of using 12V 100 amp/hr sealed lead acid battery for storage.
- Northeast US
Some questions:
- Assuming they aren't damaged, are 10 year old panels worth it?
- Would a 20A PWM Solar Charge Controller work or should I look at a larger MPPT controller with 150Voc/40a?
- Would 1 of these panels be sufficient or would I need to string 2 together?
Although this spec sheet is for the same part number, it shows a 340w panel, which these are definitely not: http://astronergy.com/attch/download/STAR_CHSM6612M_40mm frame_201801.pdf
Thanks for any recommendations!
Use Case:
- Northeast US
Some questions:
