Got a few questions with this thing. I just got it mounted in my new solar building and had it hooked just to mains to see and play with it before dragging it off grid.
1. Does the fan on this thing run all the time? Even with the inverter turned off the fans stayed on. It is barely above freezing and not actually powering anything.
2. Is it really necessary to mount it on a fireproof surface? Currently mounted on OSB.
3. Cable to do remote mounting of the display. Is it just regular network cable or do I have to make a custom one?
4. I have a Renogy Bluetooth module, any chance of being able to use it? I wouldn't have internet where it is going and I really like the idea of Bluetooth. Long shot, I think lol.
5. Cable sizing. Currently using 4 LISUATELI 12V 100Ah batteries in parallel with double 8awg wire between each posts. They have been in parallel for a few weeks now so they should be at the same SOC. Can I get away with the double 8awg to run them in series for the time being? My biggest draw is the toaster right now. Is making up steel bus bars to join the batteries a good idea?
If there is anything else I should do before I drag it to its final resting place I would greatly appreciate the advice.
BT-1 Bluetooth Module (New Version)
The Renogy BT-1 is a great addition to any compatible Renogy solar charge controllers, providing wireless monitoring of system data and allows users to change parameters through the Renogy BT/Renogy DC Home smart phone App.
www.renogy.com
