LFP cells are a dead short to a power supply/charger. It is perfectly normal for the voltage output to drop to the battery level until it is over 99% done.
You have it set to charge to 58.2v using a little over 4 amps. The fact that it is not putting out 4 amps says you should replace the leads you are using (quite common).
