ok. The inside fan is a squirrel cage and the outside one is a propeller type blade. (and again, no, they do not share anything, do not share bearings, do not share parts, only share the wall outlet).
Yes, i would rip the guts out and redesign the interior fan and use flat fans, but this is getting more complex than I want to.
Im going to try to just redesign the interior shroud and see how that goes before moving ahead.
Yes, all the options are good ideas for some builds, just not mine. I mentioned right away the mini split will not work; its due to space. The portable units are just a bad version of the original Rigid unit I was hoping that someone had used one and could chat about it, fingers crossed still. WIndow units, meh, too invasive. A window unit using hoses instead, well, about the same exact install task as the Rigid, so that just brings me back to can I use the Rigid question or do I have to have more btus...
It is really appealing to add another 300 solar to the roof and to remove the big object off the roof at the same time.
It is really appealing to have option to run ac off batteries also, and the extra 300 watts helps that a lot too....
So all that said, I really just need to find someone with experience on the Rigid before moving ahead. Opinions are nice and all, but first-hand knowledge trumps all.
