As a full-time RVer (MotorHome). Here is my list of things to consider and why.
The Multiplus is the most expensive part - go the whole way with Victron (except batteries).
1. Use a Cerbo or Cerbo-S. Having all the information together in one place is AWESOME! It has (on the touch) a nice basic screen that even my wife understands. Plus, if you have internet and are away - setup the VRM so you can keep an eye on the system - and get alerts if something (SOC) gets too low.
The Cerbo will also control the Multiplus- as an RVer, you will need to often switch the input current limit - my usual ones are 50a -35a (generator), 30a, 20a, 15a and I use 7.5amp a lot. It is a nice easy place to control the Multiplus.
2. Use the Victron Smartshunt or BMV712. You NEED to know battery SOC, and this will integrate with the rest of the stuff. It is way worth the difference in cost.
3. I added Victron Smart Battery Protects (BP65’s) on the legs going to my 12v DC fuse boxes on the rig. This way if I leave a light,etc, on and the battery gets low - it cuts off the power to the load, then when solar starts - it charges back up because the bms never went to sleep. I was strategic in selecting the cutoff voltages for the Multiplus and the BP-65’s. That way they shut down in the order I want them to. Also, that makes a great spot to reboot the 12v (furnace looking at you!). I have to reboot it about every other year.
4. When you have everything turn on DVCC in the Cerbo. This helps the system run much better for me - I have Victron equipment in four different areas using the OEM wiring that is much longer than recommended- the DVCC help compensate for voltage drops.
5. Add a “RV tank heater” to the inside of your battery boxes - with a switch for you to power it on/off - and the temperature sensor from the Multiplus on the inside of the battery box. That you you know the temperature of the batteries, if it will be too cold of a night - turn it on at night. And with DVCC turned on the solar charge controller and the Multiplus will not charge until the batteries are above _____F (user setable- mine is 40F).
You will love the equipment- remember in addition to all the small draw items - only one heavy draw item - Microwave, hairdryer, air conditioner, or two medium draw items - toaster, etc. otherwise the inverter shuts down for 1min and it tells me - hey dummy- you did it again - let’s not do that again! Then it come back on - no issues.
Good Luck on your project
