I am building a system for my 50-amp RV. I have decided on Victron components, but am struggling to decide exactly which inverter setup to go with. I want to eventually be able to run EVERYTHING in my RV off solar even if I can't do it right away. My current hang-up is that I want the power output of (2) 3000-VA inverters, I will occasionally hook into shore power, and have an onboard 5kw generator that will supplement as needed. Can you set dual inverters to handle the 50 amp or am I better off getting the 2x120? If I should have the 2x120 do you need 2 of them or can you do (1) 2x120 and 1 standard inverter? I've spent hours researching this and feel I'm no closer to finding the answer so I came here hoping for some clarity. TIA
