HomeTownHockeyFan
Solar Rookie
Details on my RV solar configuration
26’ Travel trailer (Rockwood Mini Lite 2509s)
Six 100 Watt roof mounted Polycrystalline Solar panels. (HQST)
Panels are wired in parallel pairs (2P3S)
![1588100069805.png 1588100069805.png](https://diysolarforum.com/data/attachments/12/12073-650d4f5e39d190ad80285405d5e99fae.jpg)
Victron SmartSolar 150/35 charger with BlueTooth battery sensor
2000 watt pure sine wave inverter (Renogy)
![1588100069878.png 1588100069878.png](https://diysolarforum.com/data/attachments/12/12075-d02adb38fce37f7922bfd7b4317b1a37.jpg)
Inverter is ‘hard wired’ to an Automatic Transfer Switch (Go Power)
Used switches or breakers to isolate the various components.
Replaced the standard RV Converter with one that supports Lithium (Wildkat)
Built two 280ah batteries using EVE cells. (Moved the batteries from the tongue of the trailer to the pass through storage to shift some weight off the tongue)
Using two of the 120ah SmartBMS's wired in parallel
![1588100069983.png 1588100069983.png](https://diysolarforum.com/data/attachments/12/12074-94ed1cfd1e95baa841d2335aef363628.jpg)
Used 8 gauge wire for solar panels
Used 1/0 wire for all battery, charger, and inverter wiring (Even replaced the wires running from the RV power converter)
Was a lot of work…but, very pleased with the results so far.
