The 3x 100Ah home-built batteries (looking good, BTW) each have a BMS which is programmed for maximum continuous and maximum peak current values - or in the case of some brands such as JK, the maximum peak is a property of the BMS itself, and not separately configured. I SWAG the "peak output current" of your cells to be 200A, for a few seconds. The fuse on
EACH battery pack should be fast-acting class-T and
no larger than that figure - the fuse should be protecting both BMS and the cells within the pack from higher current (which should only be present in the case of a short-circuit disaster, in which case you WANT and NEED the corresponding fuses to blow very fast.)
Going to a shared bus, that theoretically calls for a wire size of 4/0 (from each pack). However, depending on your planned Inverter size (which you have not yet indicated for us!) you could maybe consider using 2/0 from each pack, wired with matching lengths to the "12v" and "grounding" bus bars.
Within my own RV, I actually use the Inverter DC input lugs as my main "bus bars" for parallel packs, with cables from each battery all joined together at those inverter lugs ("12-VDC main input power" and "12V Grounding" respectively). Those lugs (each) also have a 3rd cable, also large, going to a car-audio-type "power distribution blocks". Whether the Inverter is powered up or turned off, the Inverter's big power lugs provide a wonderful "bus bars" for "12v" and grounding among these cables at all times. In my case, those cables are very short, and only 2/0 AWG in size. They're sized for the total capability of the Inverter while supporting AC loads, PLUS the total of all the RV "12-VDC loads added together.
Depending on the model of "Converter" and likely integrated "12-VDC Distribution Fuse Board", you will probably want to change the DC wiring at that panel. For the common case of WFCO panels, they traditionally wire one "12V" supply wire into the fuse board from the Power Converter, and another from Battery Bank. On the fuse Boards of my vintage, both of those connector ports are limited by normal-sized automotive ATC fuses (not "medium" sized, not "maxi" sized). These fuses are not generally available in sizes larger than 50A. If your Power Converter/Charger can dish out 60A, previous lead-acid batteries might not have taken it all in - and most power converters spend nearly all of their time in "float mode" anyway, putting out relatively low voltage and current.
Depending on your MAKE AND MODEL of power converter, it might actually be willing to push up to 60A into hungry LiFEPO4 battery packs. Two issues could arise in that case: #1, the maximum charging current of each "100Ah" battery pack should be limited to only 50A, so you'll generally need multiple packs accepting charge current (if you can't program a "smart" power converter to behave in a genuinely "smart" way). #2, it will exceed the maximum capability of the "12-VDC Distribution Fuse Board" main port fuses. To bypass the second issue, you will want to add another small 3-way power distribution block between the power converter and the 12VDC fuse board:
- 1 wire is the "12V" output from the power converter;
- 2 wires may now connect to BOTH main input ports of the 12-VDC fuse board, providing a higher total of power input (perhaps around 60-70A) for the RV's DC appliances;
- one wire (BIGGER) goes back to the "12v bus" or power distribution block near the batteries and Inverter. (This wire supports 2-way current, both charging the batteries and pulling from the batteries from the case of running RV "12-VDC" appliances attached at the 12-VDC fuse board).
A second small "distribution block" will be need for the grounding side, with one or two wires going into existing 12V "grounding" bus bars (probably present behind or near the '12v distribution fuse board'. As with the 12v distribution block, a larger wire should be used to make the long-distance connection back to the battery/Inverter area. I recommend use of AWG-4 for these "bigger" and longer 12v and grounding connections.
